A new type of property has been added to Smartproperties to enable assembly duplication control.
Once you've added this property to your mask, you'll see the same "Control" tab from PilotAssembly in your Smartproperties mask.
Once you've modified the values for PilotAssembly and in the dialog box, to start the duplication process, you'll need to select ProjectManager or configure SmartProperties to automatically launch ProjectManager.
When you launch ProjectManager, the attached documents will be checked by default so that the Excel file can be retrieved.
Once the documents have been duplicated, PilotAssembly will automatically run the piloting process using the new values you entered earlier.
Demo:
