This section allows you to import an assembly or a drawing using three buttons:
Add an assembly or drawing from Windows Explorer
adds the active document to SOLIDWORKS
Select documents from within 3DEXPERIENCE
Once the assembly has been imported, you can see the dependencies, including the names and locations of the files.
Right-click to access additional options:
You can define rules in the filters to automatically uncheck documents when the assembly is imported. To do this, click on the (see Filter tool).
During import, drawings are automatically inserted (see the option for searching for drawings)
