The example used for this operation is a mechanically welded frame consisting of several folded metal sheets of varying thicknesses (indicated by different colors).
By selecting the options for exporting sheet metal parts to a single DXF file containing the flattened parts grouped by thickness, the following results are obtained:
  • DXF export with all views aligned horizontally at a 1:1 scale
Details on the generated annotations and fold lines.
I requested that the list be exported in CSV format, which I then imported into Excel. Here's the result.
