When columns have been edited or created in the '' sectionNomenclatureOnce the table has been saved as a table template, it is possible to select a template from a list of suggested favorites. This list points to the directory defined in BOM options (where table template favorites are saved), but you can also add table templates from another directory. .
To save a table template, click on .
" Automatically extract all properties ": If you check this option, there is no need to customize the table template. A column will be automatically created for each property contained in the files.
