Standard orientation
Set the orientation of your views as you normally would in SOLIDWORKS
Click the "?" to be redirected to the SOLIDWORKS online help for view orientation, or click this link:
https://help.solidworks.com/2025/french/Solidworks/sldworks/HIDD_DVE_NAMED_VIEW.htm
You can configure the orientation used for the different types of bodies:
Indicate whether the front view should show the widest or narrowest part of the body.
Specify the orientation of the part (horizontal, vertical) or according to the direction of the main grain.
Choose whether SmartDrawings should orient the structure so that its largest face is horizontal or vertical.
