View Properties
Scale:
Sheet Scale: Will use the sheet's default scale
Scale: Allows you to select a scale from a list or enter the desired scale manually
Automatic scaling: Let SmartDrawings select the optimal scale for the view
Visual break:
No breaks: Applies no breaks
Automatic Break: SmartDrawings determines whether a horizontal or vertical break is needed
Horizontal break: Applies a horizontal break only
Vertical break: Applies a vertical break only
