Worksheet Creation Wizard
Selecting a part and/or assembly will generate a drawing file for each part and assembly selected in the file selection tool.
Selecting a part body (sheet metal, welded structure, solid) and/or an assembly component (part component, subassembly) will generate a sheet for each body, component, or subassembly.
Example 1:
A part consists of 3 sheet metal components and several mechanically welded components.
I just select "part" as the document type for the sheet and set up a simple view with the "isometric view" setting.
I select my part file in the file selection tool.
SmartDrawings will generate a single sheet showing an isometric view of my part.
Example 2:
I simply select "sheet metal body" as the document type to manage for the sheet, and I set up a single view with the "isometric view" setting.
SmartDrawings will generate 3 sheets for each sheet metal part, including an isometric view of the part.
