The TaskActions tool in the myPDMtools suite allows you to apply a stamp to a PDF document. This stamp can be either text or an image.
Starting with myPDMtools 2022 SP1, it is possible to automatically set the image based on a variable.
To configure this, open a TaskActions task and the "Add Stamp" operation:
We will use an Image stamp and configure it to use the “Status” variable from the document being processed to select the stamp image. Simply click the + icon to access the myPDMtools field concatenation control:
In our example, the path will be as follows:
We'll place the stamp in the center and rotate it 45°.
After the task is approved, we will process a plan document whose Status variable is: InProgress (PDFs are automatically retrieved based on the paths specified in the task settings)
The stamp used will therefore be the one named InProgress
After the task is executed via a transition or manually by right-clicking, TaskActions will automatically apply the stamp.
For a document with the status " InProgress ":
Whereas for a document with the status " Valid":
