Location
When generating the report, add numeric or alphabetic labels to the profile bars.
- Use a property as a reference point
This option allows you to define the property that will be used to identify our flow rates.
For example, I retrieve the value of the "Item" property for my reference:
- Property to be read as an identifier during the import of cross-sections
This option allows you to define the property used to distinguish between profiles.
- Column title:
This option allows you to specify the name of the column to read for "Quantity" in case that column is not named "Quantity" (2D import)
