The main interface simply indicates the number of properties that will be added or deleted during duplication. The to access the property management window.
This window will allow you to:
Increase or decrease, using the arrows the number of properties to be taken into account for processing.
Define thehe name of the new property. It can be entered manually in the window or via a drop-down list. This list points to your file defined in ownership options.
Set value. To do this, use thefield concatenation tool which allows us to apply a single value by retrieving variables from SOLIDWORKS, Windows, etc...
Define one or more property application conditions with thecondition tool. The icon indicates an applied condition.
: By clicking this icon, you can remove certain properties from the selected document, as well as from all configurations, depending on the options.
Set property application option
