Column management
The third dialog box allows you to specify which columns to display and their width, as well as to add new columns.
In this dialog box, you can "Add" a column to the display or "Remove" a column that has been added after selecting it. In fact, the columns listed up to “PDM Vault” are displayed by default and can only be “Selected” or “Deselected.” A column can be hidden from the list by setting its width to 0. For the first 9 columns, to set them to 0, you must do so directly in the list by dragging the width to the minimum using the mouse.
- The property displayed will be either the property of the document or the property of the referenced document (for example, the property of the part used in the drawing).
