Click on the buttons and areas in the image below to access the corresponding chapters
In the tool's options, you define the type of output file:
    • Let all the drawings be in a single DXF file
    • Let each one be saved in a separate DXF file
    • Each one should be shown in a separate SOLIDWORKS drawing sheet
    • Let all of them be laid out on a single SOLIDWORKS drawing sheet
To successfully complete the process:
  • Select the files to process
  • Configure the options, including specifying locations, naming the output file, defining the properties to be created, etc.
