How to Group Views by Material During an Export
How do I group views by material when exporting?
Previously impossible, the new myCADtools 2022 SP2 version now allows you to group sheet metal parts by material when exporting to DWG/DXF or creating drawings using the SheetMetalManufacturing tool.
You can find this option in the "Export Options" section:
- Implementation –
This multi-body part consists of three sheet metal bodies. Two of these bodies are made of the same material, “non-alloy steel.”
I would like to export the file in DXF format, grouping the views by material into multiple files.
I'm setting up my options:
Result: I end up with two DXF files; the tool combined the two features made of the same material into a single file.
You can group views by material or thickness.
