Report option
You can customize the indicator that appears in the SheetMetalManufacturing report after each export.
The indicator allows you to identify the bodies or files that have been processed.
Example:
We want to retrieve the "File Name" and the "MATERIAL" property of the body (plus the body name, which is required) in the indicator:
If you run the export and open the report, you'll see this:
