Selection Options
This icon opens a window containing general options.
Each sheet metal part may have properties that differ from the component's general properties.
- If the option is not checked, the properties will be retrieved and displayed based on their values.
- If this option is checked, items for which the property does not exist will take on the value of the property in the document.
For example:
Let's take a look at this part, which consists of four sheet metal components.
There is a "Material" property at the part level that is set to "1060 Alloy. "
Of the 4 items, 2 also have a "Material" property with two different values, "ALUMINIUM" and "INOX," and 2 items do not have this property.
Result obtained:
With the "Unchecked" option
With the "Checked" option
