Check/Uncheck Items
When the list of sheet metal bodies is long—such as when loading a large assembly or a large number of files—it can be tedious to select or deselect specific bodies to include or exclude them from the final processing.
- The name:
The selection rule is defined based on the name of the sheet metal body.
Example
the string "Visiativ".
- Property:
The selection mode is defined based on whether a property is present in the " welded parts " section.
It is also possible to filter based on the value of a property of the " welded parts item."
Example
- Thickness:
The selection mode is defined based on a specific thickness.
Example:Select all sheet metal parts with a sheet thickness of " 2 mm "
The final step is to click the button corresponding to the choice you want to make—" Check " or " Uncheck " all sheet metal parts that meet the criteria.
Otherwise, you can always manually select or deselect the sheet metal parts.
