For the generation location, we use the field generation tool to retrieve variables and thus build a specific rule based on the selected structure option.
You can also click on the to define a location manually and then add a variable
In the example above, if the value of the "File Location" variable is " D:\SamplesmyCADtools2021\SheetMetalManufacturing" and the value of the " Welded List Item Name " property is " Tube 80x80," then the final path will be " D:\SamplesmyCADtools2021\SheetMetalManufacturing\Tube 80x80"
