In this section, we define the date format:
  • When multiple bills of materials are requested, you can force the system to regenerate the documents each time a new bill of materials is created.
  • When retrieving properties for columns or for conditions on properties, case sensitivity may or may not be observed.
  • If you want to differentiate the display of different documents, you can assign a specific color to parts, assemblies, or welded-structure files.
  • In a bill of materials, the order in which components are displayed can either follow the order of the assembly or the order in which the components were inserted into the assembly.
