In this section, you can specify the export options for drawings in PDF format.
This is generated using the BatchConverterThe first step is to set up the tool by clicking on the icon .
  • The first option allows you to export the drawings for the selected project in PDF format when you request that the bill of materials be exported to an Excel file.
  • The second option allows you to retrieve properties from the bill of materials and insert them into the PDFs generated from the drawings. Applying this note will not modify the drawing file. For example, the quantity.
To add a note, click on . The settings window for the note to be inserted appears.
In this example, we will retrieve the value of the column in position 2 in the bill of materials, and this value will be preceded by a prefix. You can also enter text after the value.
You can then adjust the graphics settings:
  • Select a font.
  • Add a border around the note.
  • Write the note in a specific color.
Selecting one of the note placement options on the drawing allows you to place the note at the top or bottom of the sheet, or in the center of the sheet (in this case, you can specify a rotation angle for the note as if it were a stamp).
