XML export
You can specify the directory and the name of the XML export file. You can choose to use the name of the current bill of materials or create a new name using the renaming tool. This folder can be located locally or on the network so that it can be shared with multiple workstations.
This file type allows you to create the export formats you need.
Here, you can specify the folder where your XSLT files are stored. They will then be available in the drop-down menu.
You can also apply a renaming rule or retrieve the name of the XML file.
