TXT/CSV export
- You can specify the directory and the name of the BOM export file. You can choose to use the name of the current BOM or create a new name using the renaming tool. This folder can be located locally or on the network so that it can be shared with multiple workstations.
Finally, enter the character that will serve as the column separator.
- CSV format: This is the most commonly used format and allows you to create a file for each bill of materials defined in the project. You can specify a character or string to separate the values. Once the file(s) are open, you can save them with any name you choose.
Example using the "; " separator.
Example using the " [TAB] " separator.
Exporting the list of files generated by SmartBom in CSV format allows you to import that list into the "SelectFilesAndFolders" feature of batch tools such as BatchProperties, BatchConverter, etc.
