When changing a document's status, it is sometimes necessary to populate a variable using only part of the value of another variable.
For example, the service code of a document approved for manufacturing may correspond to the first characters of the Part Number.
The TaskActions tool allows you to automatically assign a value to a variable when a state changes.
To automatically assign a value to this variable, you must create a new PDM task.
We'll name this task "Service Code" and select the myPDMtools add-on:
Next, select the machine that will run the task:
The tool to use is TaskActions:
We're going to add a TaskProperties operation:
In the window that appears, we'll drag a custom field into it:
Next, we'll enter the name of the variable to be assigned a value:
We're now going to enter the value for the variable, so click on
Then enter the variable you want to retrieve:
To retrieve only a part of the string, just click on
In our case, we want to retrieve the characters that come before the – character
So we'll select "Split by character –" and index 1, which corresponds to the first occurrence of the string separated by a -
TaskActions will automatically handle the extraction and archiving of documents:
All you have to do is confirm the creation of the task.
Then add the action to be performed during the transition:
Thus, the Service Code will be automatically populated when the document is validated:
