The user can choose the method for optimizing the bars. The choice of method may affect:
    • The number of bars found
    • Calculated cutting times
    • Computing time
Quick Method:
This option is suitable for large projects—that is, projects involving a large number of cuts per profile. The calculation time will be shorter and will not affect the optimization.
Optimized Method:
This option is suitable for small and medium-sized projects. If used for large projects, the computation time will be much longer.
Automatic Method:
As the comment indicates, the utility selects the most appropriate algorithm based on the size of the project.
The bars can be sorted by ascending or descending size, or by reference.
