Certain properties can be added to the Excel file when the bill of materials is exported. There is no limit to the number of properties that can be added, and the list can be saved as a favorite in a folder.
You can save your favourites in a specific folder and retrieve this folder. .
Once you've selected a folder, you'll see your favorites in the drop-down menu. You can then add update or delete .
When you want to define a field to retrieve the value of a SOLIDWORKS document property, a system variable or simply define a fixed value, simply click on the icon (Add a field). This function allows you to concatenate several values. See theoption in detail.
Once you've set the value, you must specify the name of the cell in Excel to which you want to apply this property.
Then all you have to do is click Add.
Here's what you get:
