Find the file based on the source file:
Sometimes it is necessary to upload the associated file—for example, a PDF of a SOLIDWORKS drawing—to SharePoint, rather than the source SOLIDWORKS drawing file.
To perform this action, simply check the box next to the option:
Next, simply enter the name of the file you want to search for—including its extension—using the Variable Concatenation tool,along with its location.
By default, the tool searches for a PDF file named after the source file, with the .pdf extension, in the PDF subfolder of the processed file.
The published file will be named using the name specified in the Generation Location
