Overview
Click on the buttons and areas in the image below to access the corresponding chapters
CuttingOptimization features:
- Creating a database of profiles.
- You can create a project based on a welded-assembly table, or you can create a project and manually enter the list of profiles.
- Using the options settings,you can specify a number of parameters, such as the default location for projects and output files.
