Column management
You can customize the columns:
- by clicking on the
- by right-clicking and selecting "Column Management"
This command allows you to disable, add, or delete columns:
- To hide a column, simply uncheck the corresponding row:
- To delete or add a column, right-click on the corresponding row and select " Delete Custom Column " or " Add Custom Column ":
Double-clicking on the "Name" row allows you to enter a custom header; this also applies to existing rows.
Example: Let's add the "Material" column, which is a property of a welded part item in the bill of materials table; be sure to use the correct syntax and case for the property name. Next, there are two types of properties: “ Simple Property” and “Distinguishing Property” (double-click the “Type” column).
- A " Simple Property" allows you to enter information about the profile
- A "distinguishing property " makes it possible to distinguish between profiles of identical shapes based on another criterion.
For example, in this case, if the “Material” property is of the type “ Differentiating Property,” the “D” label will be optimized independently; it will not be mixed on bars with other flow rates that do not have this same property.
