Machine & Bars
- Choosing bar lengths:
- Required:
This option allows you to specify a bar length for all profiles.
- Fall management:
If you have offcuts in your inventory, you can enter their lengths here; they will be taken into account when cutting the pieces.
- Define by profiles:
This option allows you to specify a bar length for each profile.
See paragraph ''Define bar length per profile''.
- Treatment:
This field allows you to add information to the report header regarding the finish of the bars (e.g., painted, anodized, uncoated, etc.).
- Machine:
- Blade width:
By default, the cut width is retrieved from the options. This value can be changed for the active project.
- Initial drop:
Portion subtracted from the length of the bar before optimization: This portion corresponds to the various losses associated with different sawing machines (in the case of a double-blade machine, this corresponds to the systematic “resawing” of each length; in the case of a single-blade machine, it corresponds to the pre-cutting of the bar, etc.).
- Angle measurements:
(See "Entering Items")
Initialization of the angle value at the ends. In some companies, the edge perpendicular to the bar's axis is:
- Let 0° be taken as the reference point
- Considered at 90°
Example: In the first case, the cutting angle will be 30°, whereas in the second case, for the same cut, the angle will be 60°.
The values in the flow rate list are recalculated immediately when you change the option.
