Rename documents without losing the reference links
This feature will allow you to rename components using one or more naming rules without losing the references in the reference links.
To set the naming rule, use the field generation tool. You can also retrieve a variable and apply a retrieval option to it.
You can apply the naming convention:
- across the entire database defined in theFindDocument Service
- from a CSV file list
- on one or more specific issues
