Replacing a component
Replacing a Component
This feature allows you to replace one component with another in all parts where that component appears.
Both the replaced component and the replacement component must be present in the database being analyzed in the FindDocuments service configuration.
Example:
This procedure will replace the " 090-Right Inner Housing " component with the " 090-Left Inner Housing " component.
